306Orbi
Jul 03, 2022Star
ORBI 963E And Which Satellite Acquires A Device
I know this has been discussed before - but my purpose of this post is if someone has figured out a way to solve this problem in a ORBI 963E and Satellites System. I have a ORBI 963E Router and 3 Sa...
- Jul 03, 2022
Because its upto devices to pick and choose where they connect too. Not Orbi.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.Try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
306Orbi
Jul 03, 2022Star
I am Happy too report that after setting the RBR 2.4GHZ to 50%.... the Generator is now showing connected to The Closest Satellite (Bedroom Satellite) the link is showing at 57MBPS ... wish it was 72 🙂
The connection bars for the generator are showing at two bars ... so not 3 bars which are max.
But the Generator Access point switched to this Satellite without rebooting the Router.. which is great news.
Now I will monitor if other devices are affected due to signal strength for 2.4GHZ being reduced to 50%...and report back if there are any issues.
Thanks for your help again.
Jul 04, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
