kirkmc
Aug 17, 2022Guide
Orbi, AirPlay, and Sonos
I have a Netgear Orbi BK753 system, which I upgraded recently from a BK50. For more than five years, I have had very few problems sending audio from my iMacs to the Sonos Amp via AirPlay. The iMac is...
Aug 17, 2022Guru - Experienced User
Is the sonos amp connected to the router or the satellite?
If you read on the sonos forums, there's a bunch of reports of issues with mesh systems on there. You might ask for help on there as they'll be more familiar with getting their product working properly.
- kirkmcAug 17, 2022Guide
It's connected to the router. I've asked on the Orbi forums, and haven't gotten any satisfactory replies. As I said, it worked fine before with the RBK50.
- plemansAug 17, 2022Guru - Experienced User
Are you using icloud relay or private mac/ip address on the mac/ios devices? If so, disable it
