kirkmc
Aug 17, 2022Guide
Orbi, AirPlay, and Sonos
I have a Netgear Orbi BK753 system, which I upgraded recently from a BK50. For more than five years, I have had very few problems sending audio from my iMacs to the Sonos Amp via AirPlay. The iMac is...
Aug 17, 2022Guru - Experienced User
Is the sonos amp connected to the router or the satellite?
If you read on the sonos forums, there's a bunch of reports of issues with mesh systems on there. You might ask for help on there as they'll be more familiar with getting their product working properly.
kirkmc
Aug 17, 2022Guide
It's connected to the router. I've asked on the Orbi forums, and haven't gotten any satisfactory replies. As I said, it worked fine before with the RBK50.
- plemansAug 17, 2022Guru - Experienced User
Are you using icloud relay or private mac/ip address on the mac/ios devices? If so, disable it
