MonkeyIsland
Apr 23, 2022Aspirant
Orbi Airprint problems with Epson ET-2650
Hi, I was using my Epson ET-2650 with other Wifi system (Non NetGear) during the last 2 years without any issue. Recently I migrated to Orbi (RBKE963). Printer is visible during a few minutes aft...
Mikey94025
May 11, 2022Hero
Airprint visibility has often plagued me in my Orbi AXE network. I have 3 wireless printers (2 HPs and one Canon) and often my iPhone will only show one of them. It may change which one shows up the next time I try to print.
I looked at it again now because I could only see one of the HP printers. I followed the instructions in https://community.netgear.com/t5/Orbi/Orbi-Bonjour-and-Airprint-fix-at-least-for-me/m-p/1883437 and now I can see all 3 printers on my iPhone:
- So to enable it go to the Orbi admin console --> advanced --> setup --> LAN setup --> in LAN TCP/IP Setup --> RIP version --> RIP_2M should be selected.
So try changing your RIP version to RIP_2M and see if that improves things for you. For me, that setting was previously set to RIP_1. I'm not sure why and may have been a prior attempt to fix Airprint.
MonkeyIsland
May 12, 2022Aspirant
Hi Mikey94025
I already tried that solution and it did not work.
In this moment, I think there is some bug in the latest firmware of my Orbi system.
Best Regards,
Abel
