SeanZann
Feb 14, 2022Aspirant
Orbi and AT&T 5g Microcell
I have the Orbi (but the model says SXK30 - not sure exactly which one I was supposed to pick from the dropdown). And AT&T MicroCell they have sent us to replace our old 3g one. They are saying I n...
Feb 14, 2022Guru - Experienced User
If you run through setup on the microcell, does it work?
where is it failing if not?
