SeanZann
Feb 14, 2022Aspirant
Orbi and AT&T 5g Microcell
I have the Orbi (but the model says SXK30 - not sure exactly which one I was supposed to pick from the dropdown). And AT&T MicroCell they have sent us to replace our old 3g one. They are saying I n...
SeanZann
Feb 15, 2022Aspirant
That's what I was thinking - their instructions are for opening up a firewall or other kind of more deeply secured network. I'm on a Charter/Spectrum Arris Model TM1602A
I never see the 4g LTE on our phones, but I do see a difference in bars when it's supposedly connected. It just only seems to go through about 10% of the time.
Thanks for the assitance so for, to everyone!
Feb 15, 2022Guru - Experienced User
OK, kewl. Just making sure you didn't have any double NAT condition. Hopefully a replacement MCell will work. You shouldn't need any configuration on the Orbi. Used to be that DMZ was needed with the older MCell years ago.
- SeanZannFeb 15, 2022Aspirant
Thanks a lot! This will help me tell that I have confirmed my router settings are not a problem. I appreciate it! and I'll let everyone know when I get a replacement if it works.
- FURRYe38Feb 15, 2022Guru - Experienced User
Sounds good. FYI. Give the new MCell several minutes to come to ready. All Front LEDs should turn on solid WHITE. The back ethernet Internet port will always blink green regarless of activity. Make sure you have a good LAN cable too. CAT6 is recommended.
