hammie1234
Dec 21, 2020Aspirant
Orbi and EPSON ET-4750 Wireless Printer
Hi, I had a Google Nest Router for several years and just bought the Orbi rourter. Transition has gone mostly smooth. I am having difficulties printing on my EPSON ET-4750 Wireless Printer. ...
- Dec 21, 2020
I had done the previous steps, then uninstalled my driver, and still could not print.
After more digging, I uninstalled the device (not just driver) and reinstalled both the device and driver. Printing has resumed! Thank you.
Mstrbig
Dec 21, 2020Master
hammie1234 wrote:Hi,
Following the boards, I have done the following:
- CTS/RTS Threshold (1-2347): set to 2347
- Set 2.4ghz channel to 11
- Rebooted Router, Satellite, Cable Modem, Printer
It takes about 20 seconds for my computer to connect to the printer, but when it finally does, it does not successfully print. Any thoughts?
I set my CTS/RTS Threshold to 1500
Your 2.4 Ghz will be determined by the traffic you have on different. 11 may be ok, but 1 or 6 may be better.
Re-configure your printer back on the WIFI or check to make sure it is still connected. On your PC, remove and re-install the printer. Then if needed, search for it again. I usually remove the driver as well, but it is not necessary. This final step should resolve the issue.
hammie1234
- FURRYe38Dec 21, 2020Guru - Experienced User
Please mark your thread as solved so others will know.
Enjoy. :smileywink:
