Chief2019
Mar 09, 2022Tutor
Orbi and internet dropping
I have had the Orbi RBS750 with a Spectrum internet modem working together since October of 2021. In the middle of February 2022 the internet starting dropping randomly. There were no internet outa...
- Mar 09, 2022
The problem was a splitter on the box outside the house. Thanks again
Chief2019
Mar 09, 2022Tutor
Thank you both. I have Spectrum coming out to check the modem
Chief2019
Mar 09, 2022Tutor
- FURRYe38Mar 09, 2022Guru - Experienced User
Awesome. Glad you found the problem child. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡 - TC_in_MontanaMar 09, 2022VirtuosoLike FURRYe38 said - happy you figured it out - and happy Spectrum fixed it! Also glad you were willing to ask Spectrum to double check on their side/equipment. A lot of users automatically assume that it's the router when many times it is not and are not willing to give other issues full consideration. Happy Computing!
