Apr 22, 2024Guru - Experienced User
Orbi and IPv6 Feedback and Experiences
For those with a Orbi AX or AXE systems and whom have native IPv6 support from there ISP, when you get a chance could you please check out how IPv6 is working if your ISP supports it natively. Especi...
owlyn
Apr 24, 2024Luminary
I’m on Comcast. The only time I have a problem 9/10) is if I have either of the Netgear Armor VPNs on (Safe Browsing or Hydra). When either of these are on, I get the DNS problem in the IPV6 test (9/10). I am set on Auto and specifically use the Comcast DNS addresses ( not get automatically, I have them entered).
If anyone is having a problem, it is probably due to a VPN.
donawalt
Apr 24, 2024Mentor - Experienced User
I have had IPv6 problems as reported above and I don't use a VPN.
- FURRYe38May 13, 2024Guru - Experienced User
Any updates on this?
- donawaltMay 13, 2024Mentor - Experienced User
Ever since I changed from auto-DNS detection on IPv6 to manual entry of the 2 Google IPv6 DNS servers, no problems!
