Apr 22, 2024Guru - Experienced User
Orbi and IPv6 Feedback and Experiences
For those with a Orbi AX or AXE systems and whom have native IPv6 support from there ISP, when you get a chance could you please check out how IPv6 is working if your ISP supports it natively. Especi...
Deihmos
May 15, 2024Guide
On Verizon Fios, the only option that works is auto config but there is ipv6 address on wan available. Anyone with Fios experience the same? I am using the most recent firmware.
- FURRYe38May 15, 2024Guru - Experienced User
Do you get other IPv6 options on the IPv6 menu page?
Using ISP IPv6 DNS or any custom IPv6 DNS?
What are your IPv6 testing results from the IPv6 testing site?
- DeihmosMay 15, 2024Guide
There are other options such as DHCP but it does not work. The only option that work is auto config. I use Google DNS because the ISP does not provide any. Ipv6 works fine, my only concern is why the wan address says unavailable. Clearly, ipv6 is an after thought on the router. The Verizon branded router provides a lot more data.
