Apr 22, 2024Guru - Experienced User
Orbi and IPv6 Feedback and Experiences
For those with a Orbi AX or AXE systems and whom have native IPv6 support from there ISP, when you get a chance could you please check out how IPv6 is working if your ISP supports it natively. Especi...
Deihmos
May 15, 2024Guide
On Verizon Fios, the only option that works is auto config but there is ipv6 address on wan available. Anyone with Fios experience the same? I am using the most recent firmware.
May 15, 2024Guru - Experienced User
Do you get other IPv6 options on the IPv6 menu page?
Using ISP IPv6 DNS or any custom IPv6 DNS?
What are your IPv6 testing results from the IPv6 testing site?
- DeihmosMay 15, 2024Guide
There are other options such as DHCP but it does not work. The only option that work is auto config. I use Google DNS because the ISP does not provide any. Ipv6 works fine, my only concern is why the wan address says unavailable. Clearly, ipv6 is an after thought on the router. The Verizon branded router provides a lot more data.
- FURRYe38May 15, 2024Guru - Experienced User
- donawaltMay 23, 2024Mentor - Experienced User
This is additional information for the Engineers, as I had another IPv6-related failure. I also have links to 2 dropbox files which are LAN/WAN debug captures, which I sent to Netgear but are not linked here.
I added this info to my support ticket #48125362.
This morning I woke to find that my iPhone 15 (purchased fall 2023) and my new iPad Pro (new last week) both had lost WiFi. In both cases, the WiFi Settings showed a connection to my network, yet the top right corner said "5G". I verified in Speediest that the network being used was my cellular carrier not my WiFi network. Also, I checked the RBR960 and both RBS960s, and none had any colored lights for the LED. I checked their debug pages, all was fine - memory and CPU was stable and where it should be, both RBSs showed a hop count of 1.
I also plugged my phone into an ethernet cable, and that worked fine. So the Internet/from Comcast, my modem, the router were all fine supplying network access. Only WiFi was failing.
Other Apple devices in the house were fine. I checked a MacBook Pro 2023, MacBook Pro 2022, iPhone SE (4-5 years old), and an iPad (around 5 years old). Things I tried, to restore WiFi on these 2 devices, without success:
- I turned WiFi off and on, on the device.
- I moved around the house and tested next to both RBSs and the RBR.
- Since both devices support the WiFi 6E standard, I turned that off, to see if WiFi 5 was available. It was not.
- Private WiFi address is turned off on my home network. I tried with it turned on.
- Limit IP address tracking is normally turned on - I tried with it turned off.
- I restarted the deviceSo I finally found something that worked. I did a Reset Network Settings on both devices. Then, I re-added them to the WiFi network. All worked fine! So at this point, I thought maybe just something got messed up on the new devices, or it could be an issue with the Orbi and newer devices working. But then...
I went to put both devices on their manual IP addresses. I have about 6 devices in the house on manual addresses, starting at 192.168.1.152 (my DHCP pool is 192.168.1.1- .150). Note, DHCP is provided by the Orbi RBR960. As soon as I added the manual IP address, WiFi was lost! I went back to automatic DHCP, and it worked. I readied the manual entry, and 5G came back! So it seemed at this point, the RBR960 was not able to handle a manual IP address. I made sure there was no conflict on the ip address being used.
At this point, I left the devices on automatic so they would have WiFi. I did some more testing and checking things out, and I discovered NO DEVICE on the network had IPv6 - it said when I tested, that there was no public IPv6 address that the test server could see. IPv6 had been fine for at least a month, since I turned off the default IPv6 DNS servers (Comcast), and manually entered two IPv6 Google DNS servers. So then, I did what I have done in the past to restore IPv6 - I re-selected DHCP on the Advanced/IPv6 page on the router admin page, and IPv6 came back for everybody.
One last piece though - I went back, and found I had no issues entering a manual IP address for the two devices! So the IPv6 failure seemed to kill the manual IP address use of two late-model devices.
There are 2 debug capture files. One is called "Debug Log no WiFi.zip". While this was running, I made a point to turn off/on WiFi on the devices, thinking maybe a failure would be seen in the log file.
The second log file is "Debug Log ipv6 fail and redetect.zip" - this was running after I discovered IPv6 had failed, and I continued to have it run through the re-detect of DHCP on the Advanced /IPv6 page of the router.
I can provide these if anyone else needs them - they are linked on support ticket #48125362.
