Apr 22, 2024Guru - Experienced User
Orbi and IPv6 Feedback and Experiences
For those with a Orbi AX or AXE systems and whom have native IPv6 support from there ISP, when you get a chance could you please check out how IPv6 is working if your ISP supports it natively. Especi...
Jgoldsti
Jun 14, 2024Star
I am using ipv6 with google nest smoke abs carbon monoxide detectors. I ran the ipv6 test with spectrum and got a 10/10
Jun 14, 2024Guru - Experienced User
Are you using ISP detected IPv6 DNS or custom IPv6 DNS?
- JgoldstiJun 14, 2024Star
ISP detected
- FURRYe38Jun 14, 2024Guru - Experienced User
I do have occasional weird problems where the units lock up. When I reboot them, they loose the settings. Happens every several months. Not that often and not that annoying.
unfortunately the Google nest smoke detectors use IPv6 to communicate with each other.
