Apr 22, 2024Guru - Experienced User
Orbi and IPv6 Feedback and Experiences
For those with a Orbi AX or AXE systems and whom have native IPv6 support from there ISP, when you get a chance could you please check out how IPv6 is working if your ISP supports it natively. Especi...
Jun 14, 2024Guru - Experienced User
Are you using ISP detected IPv6 DNS or custom IPv6 DNS?
Jgoldsti wrote:
I am using ipv6 with google nest smoke abs carbon monoxide detectors. I ran the ipv6 test with spectrum and got a 10/10
Jgoldsti
Jun 14, 2024Star
ISP detected
- FURRYe38Jun 14, 2024Guru - Experienced User
- JgoldstiJun 14, 2024Star
I do have occasional weird problems where the units lock up. When I reboot them, they loose the settings. Happens every several months. Not that often and not that annoying.
unfortunately the Google nest smoke detectors use IPv6 to communicate with each other.
Something to try some custom IPv6 DNS configurations and see if this changes any of those behaviors.
