BluntAttack
Jun 25, 2020Aspirant
Orbi and Modern Warfare Nat
I have RBR750 with two satellites. Two Xbox Ones. Both always show Open Nat in the console settings. Both always show Moderate in Modern Warfare menu. My older Nighthawk will show Open in game, but Mo...
Jun 25, 2020Guru - Experienced User
Is is a known NAT issue with v15.25 and all prior versions of FW. I have filed a bug report on this.
Do you still have your prior router?
What is the model # of this NG router?
BluntAttack
The modem is “Spectrum E31T2V1“ and the NG is RBR750 with two satellites. No longer have the Nighthawk. The most recent version I had was the little black box mesh system. Which constantly lost connection on one of the satellites, so I returned it and got this Orbi. Which much much better, but apparently crushed by it’s less than great FW. Which sucks. Eero is a tinker toy as far as networking goes, but out of the box it did give open NAT in Modern Warfare, just laughable WiFi speeds. So it went back too. Apparently an open NAT is too big of an ask for modern routers. Ha. My old school 3 antenna AC Nighthawk was pretty perfect, except for its super short range. I’m happy to beta test any firmware or do pretty much anything to make this NAT issue go away - because the radios on this Orbi are really something and I really hope it can stay.
- FURRYe38Jun 25, 2020Guru - Experienced User
I would make contact with a forum Moderator and ask about a beta that maybe available to you.
