Chief2019
Mar 31, 2021Tutor
Orbi and Panasonic Homehawk camera not connecting
I recently installed a new orbi AX 4200 router. When trying to connect my Panasonic Homehawk shelf cameras I can not connect and am told by the homehawk app that I need to diable the isolation setti...
- Mar 31, 2021
I finally got them to work after doing a 30 second unplug and plugback in and reset on the camera. multiple tries later it worked. Thank you for the help.
Mar 31, 2021Guru - Experienced User
Orbi doesn't support nor have isolation setting.
Are these 2.4Ghz cameras that use a installation mobile app to install them?
- Chief2019Mar 31, 2021Tutor
They are dual band I think. We use the Homehawk app to connect them. https://apps.apple.com/us/app/homehawk/id1324939168 https://shop.panasonic.com/home-and-office/connected-home/KX-HNC800B.html
- FURRYe38Mar 31, 2021Guru - Experienced User
I would refer to the mfr support site and help on how to get them installed. Only item that seems to cause problems is that some IoT devices don't like single SSID wifi broadcasts from some wifi system. Like Orbi, it only broadcasts 1 SSID name for both 2.4 and 5Ghz. Some IoT mfr software only supports 2.4Ghz which in unfortunate as both 2.4 and 5Ghz are technially on the same network.
You might inquire of the Mfr about if there setup software needs the mobile device to be on 2.4Ghz only or can it be on either.
By mobile devie do you mean my ipad with the setup app or the camera I am trying to setup?
