Chief2019
Mar 31, 2021Tutor
Orbi and Panasonic Homehawk camera not connecting
I recently installed a new orbi AX 4200 router. When trying to connect my Panasonic Homehawk shelf cameras I can not connect and am told by the homehawk app that I need to diable the isolation setti...
- Mar 31, 2021
I finally got them to work after doing a 30 second unplug and plugback in and reset on the camera. multiple tries later it worked. Thank you for the help.
Mar 31, 2021Guru - Experienced User
Orbi doesn't support nor have isolation setting.
Are these 2.4Ghz cameras that use a installation mobile app to install them?
Chief2019
Mar 31, 2021Tutor
They are dual band I think. We use the Homehawk app to connect them. https://apps.apple.com/us/app/homehawk/id1324939168 https://shop.panasonic.com/home-and-office/connected-home/KX-HNC800B.html
