Chief2019
Mar 31, 2021Tutor
Orbi and Panasonic Homehawk camera not connecting
I recently installed a new orbi AX 4200 router. When trying to connect my Panasonic Homehawk shelf cameras I can not connect and am told by the homehawk app that I need to diable the isolation setti...
- Mar 31, 2021
I finally got them to work after doing a 30 second unplug and plugback in and reset on the camera. multiple tries later it worked. Thank you for the help.
Mar 31, 2021Guru - Experienced User
I would refer to the mfr support site and help on how to get them installed. Only item that seems to cause problems is that some IoT devices don't like single SSID wifi broadcasts from some wifi system. Like Orbi, it only broadcasts 1 SSID name for both 2.4 and 5Ghz. Some IoT mfr software only supports 2.4Ghz which in unfortunate as both 2.4 and 5Ghz are technially on the same network.
You might inquire of the Mfr about if there setup software needs the mobile device to be on 2.4Ghz only or can it be on either.
Chief2019
Mar 31, 2021Tutor
I did not really get any place with the manufacturer.
- FURRYe38Mar 31, 2021Guru - Experienced User
Try disabling AX Mode on the RBR and set CTS values to 2347.
AX mode are check boxes on the Basic/Wireless settings page on the RBR.
CTS is under Advanced Tab/Advanced Settings/Wireless Settings - Chief2019Mar 31, 2021Tutor
Glad you got them working. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
