Chief2019
Mar 31, 2021Tutor
Orbi and Panasonic Homehawk camera not connecting
I recently installed a new orbi AX 4200 router. When trying to connect my Panasonic Homehawk shelf cameras I can not connect and am told by the homehawk app that I need to diable the isolation setti...
- Mar 31, 2021
I finally got them to work after doing a 30 second unplug and plugback in and reset on the camera. multiple tries later it worked. Thank you for the help.
Chief2019
Mar 31, 2021Tutor
I did not really get any place with the manufacturer.
Chief2019
Mar 31, 2021Tutor
- FURRYe38Mar 31, 2021Guru - Experienced User
Glad you got them working. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
