droog
Oct 13, 2020Star
ORBI AP mode and ethernet backhaul
Hi, I've been having some trouble setting up wired ethernet backhaul in my home environment. My gateway/perimeter appliance is a black box from from the ISP (1000Mbit fibre into an IPTV route...
- Oct 17, 2020
Glad you got it working. I new you would.
Please mark your thread as solved so others will know.
Enjoy. :smileywink:
droog
Oct 14, 2020Star
FURRYe38 wrote:
RBS should be wirelessly synced first, then ethernet connected afterwards.
OK, that is helpful. After I posted this I tried moving the ethernet cable in the RBR from the WAN port to the next one over. All of a sudden I saw the satellite. In fact, I saw 2 devices one wired and one wireless. Similar MAC addresses, not sure if this is a problem or not.
But there was another problem: now I see the satellite is broadcasting my SSID on 5GHz but a different SSID on 2.4. And the one that matches somehow has security "non" instead of the chosen password from the router.
So I hard reset everyhing and started over (now for the third time). A few hours I got the satellites connecting, to the router (in router mode). Phew!
Then change the router to AP mode, and bam! The satellites cannot be found. This has to be the hardest and most frustrating end-user experience of any consumer electronics product I have ever used in over 20 years. I'm about ready to give up :-(
Cheers,
Droog
Oct 14, 2020Guru - Experienced User
The WAN port on the RBR has to be use always in router or AP Mode. Both RBS need to be connected to the back of the RBR or can be connected to a switch that is connected to the back of the RBR while in AP Mode:
