droog
Oct 13, 2020Star
ORBI AP mode and ethernet backhaul
Hi, I've been having some trouble setting up wired ethernet backhaul in my home environment. My gateway/perimeter appliance is a black box from from the ISP (1000Mbit fibre into an IPTV route...
- Oct 17, 2020
Glad you got it working. I new you would.
Please mark your thread as solved so others will know.
Enjoy. :smileywink:
droog
Oct 17, 2020Star
Fixed. All working now.
I had the WAN port on the router connected to the ISP modem, but I did not have a separate wired connection (port #2) connected for backhaul. The other ports were all connected to regular wired devices. That was the config problem. Soon as I added that line, it all worked.
My suggestion would be to update the network topology diagrams to include the ISP to WAN port on router as well as the router-to-satellite connections.
Cheers,
Droog
Oct 17, 2020Guru - Experienced User
Enjoy. :smileywink:
