MiddKid
Jun 09, 2021Guide
Orbi App and orbilogin.net stop working
Current set-up: RBR850 Router RBS850 Satellite - Wired Backhaul RBS850 Satellite - Wired Backhaul RBS750 Satellite - Wired Backhaul RBS750 Satellite - Wireless Backhaul My system is working g...
Jun 09, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
Is Armor enabled on the RBR?
- MiddKidJun 09, 2021Guide
Had to go reboot in order to answer your questions!
Firmware: 3.2.18.1. No updates available
Connected to Arris SB8200 (running Xfinity Internet)
Over the last month I've had to power cycle the system numerous times to get the app/orbilogin.net to work. And to reiterate, the actual network is working fine, just need to reboot to re-acquire access to the app/site.
Armor is not enabled
- FURRYe38Jun 09, 2021Guru - Experienced User
Have you tried accessing 192.168.1.1 instead of orbilogin.net?
Has a factory reset and setup from scratch been performed since last update?
Yes, I've tried accessing the IP directly when the issue happens. It still just hangs and doesn't connect.
No, I have not done a full factory reset. Was trying to avoid that as the network itself seems to be working quite well aside from this occasoinal inability to access the network management tools.
