MiddKid
Jun 09, 2021Guide
Orbi App and orbilogin.net stop working
Current set-up: RBR850 Router RBS850 Satellite - Wired Backhaul RBS850 Satellite - Wired Backhaul RBS750 Satellite - Wired Backhaul RBS750 Satellite - Wireless Backhaul My system is working g...
Jun 09, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
Is Armor enabled on the RBR?
MiddKid
Jun 09, 2021Guide
Had to go reboot in order to answer your questions!
Firmware: 3.2.18.1. No updates available
Connected to Arris SB8200 (running Xfinity Internet)
Over the last month I've had to power cycle the system numerous times to get the app/orbilogin.net to work. And to reiterate, the actual network is working fine, just need to reboot to re-acquire access to the app/site.
Armor is not enabled
- FURRYe38Jun 09, 2021Guru - Experienced User
Have you tried accessing 192.168.1.1 instead of orbilogin.net?
Has a factory reset and setup from scratch been performed since last update?
- MiddKidJun 09, 2021Guide
Yes, I've tried accessing the IP directly when the issue happens. It still just hangs and doesn't connect.
No, I have not done a full factory reset. Was trying to avoid that as the network itself seems to be working quite well aside from this occasoinal inability to access the network management tools.
- FURRYe38Jun 10, 2021Guru - Experienced User
Try a reset on the RBR and setup from scratch using a web browser...
