MiddKid
Jun 09, 2021Guide
Orbi App and orbilogin.net stop working
Current set-up: RBR850 Router RBS850 Satellite - Wired Backhaul RBS850 Satellite - Wired Backhaul RBS750 Satellite - Wired Backhaul RBS750 Satellite - Wireless Backhaul My system is working g...
Jun 09, 2021Guru
Have you tried accessing 192.168.1.1 instead of orbilogin.net?
Has a factory reset and setup from scratch been performed since last update?
MiddKid
Jun 09, 2021Guide
Yes, I've tried accessing the IP directly when the issue happens. It still just hangs and doesn't connect.
No, I have not done a full factory reset. Was trying to avoid that as the network itself seems to be working quite well aside from this occasoinal inability to access the network management tools.
- FURRYe38Jun 10, 2021Guru
Try a reset on the RBR and setup from scratch using a web browser...
