May 26, 2020Guru - Experienced User
Orbi App can't connect to RBR850 in AP mode...
Just wondering if anyone here in the Orbi AX forums has noticed that either Apple or Android versions or both, that Orbi app can no longer connect to the RBR850 when in AP mode? Seems that it wa...
Ok, thank you for letting us know. I'll pass this along.
farmrt88
May 26, 2020Star
Thanks for passing the issue along.
I'm also unable to access orbilogin.net from WIFI connected Windows PCs. The only way to access the admin page is by hard wire connecting to the ORBI Router or Satelite.
Accessing orbilogin.net over WIFI times out.
- FURRYe38May 26, 2020Guru - Experienced User
Interesting, something all try. I always access the RBR in ap mode using it's assigned static IP address, 192.168.0.85 on my network. I'll give this a go when I get home.
Confirmed, I can't access the RBR in AP mode with orbilogin.net either. I can using it's IP address.
