May 26, 2020Guru - Experienced User
Orbi App can't connect to RBR850 in AP mode...
Just wondering if anyone here in the Orbi AX forums has noticed that either Apple or Android versions or both, that Orbi app can no longer connect to the RBR850 when in AP mode? Seems that it wa...
Toggil1
May 27, 2020Aspirant
Same thing happens to me in AP mode on the Samsung Orbi App, without a factory reset on the latest firmware. It says the other Netgear Router R9000 model is unsupported.
The work around is to connect remotely to the RBR850 in the App
May 27, 2020Guru - Experienced User
Is your RBR in AP mode set for Dynamic IP address assignment or set for Static IP address?
Toggil1 wrote:Same thing happens to me in AP mode on the Samsung Orbi App, without a factory reset on the latest firmware. It says the other Netgear Router R9000 model is unsupported.
- Toggil1May 27, 2020Aspirant
it is set to dynamic ip address
- FURRYe38May 27, 2020Guru - Experienced User
Ok, well I was hoping that maybe that was a factor. Mines set for static and I see this problem as well.
How about setting up a IP address reservation on your host router for the RBR in AP mode...this make any difference?
- Toggil1May 27, 2020AspirantHey, i have ip reservation 1..1..1.104, just the app that you have to go in with remote management, otherwise it works great
