May 26, 2020Guru - Experienced User
Orbi App can't connect to RBR850 in AP mode...
Just wondering if anyone here in the Orbi AX forums has noticed that either Apple or Android versions or both, that Orbi app can no longer connect to the RBR850 when in AP mode? Seems that it wa...
May 31, 2020Guru - Experienced User
Well, this seems to be a problem again. Orbi app was updated two days ago v2.5.2.1. Power was off sometime yesterday when I was not home then we had a ISP outage. I didn't check the Orbi app yesterday after services were restored. Woke this morning to check on the app and again, the app is reporting "Unsupported router" message in the app. :smileyfrustrated:
Christian_R
Jun 01, 2020NETGEAR Employee Retired
Hello Orbi AX Family,
Curious to know if you guys have had a chance to roll back a previous firmware version on the RBR850. If so, I'm interested in hearing the results.
Thanks,
Christian
- FURRYe38Jun 02, 2020Guru - Experienced User
I have not. I will do this this today. I need to anyways as v15.25 is causing my 1 NEST controller to not keep connected very well.
I'll report back my findings.
Christian_R wrote:Hello Orbi AX Family,
Thanks,
Christian
Ok, I just downgraded the RBS and RBR to v11.2. Rebooted everthing.
I can access the RBR in AP mode using the app on both apple and android:
Thanks,
Christian
