May 26, 2020Guru - Experienced User
Orbi App can't connect to RBR850 in AP mode...
Just wondering if anyone here in the Orbi AX forums has noticed that either Apple or Android versions or both, that Orbi app can no longer connect to the RBR850 when in AP mode? Seems that it wa...
Toggil1
May 27, 2020Aspirant
Same thing happens to me in AP mode on the Samsung Orbi App, without a factory reset on the latest firmware. It says the other Netgear Router R9000 model is unsupported.
The work around is to connect remotely to the RBR850 in the App
Christian_R
Jun 02, 2020NETGEAR Employee Retired
Hello FURRYe38, farmrt88, and Toggil1,
I noticed most of you mention that you have Android. Would you guys mind confirming the current Orbi app version you have installed on your Android device. I've brought this up to our product teams, thanks everyone for bringing this to our attention.
Best,
Christian
- FURRYe38Jun 02, 2020Guru - Experienced User
v2.5.4.1036.
Just checked the Google store, nothing new available.
- pkgaddJun 05, 2020Luminary
orbi app v2.5.4.1036 on android 7.1, android 9 and android 10 all show the same behaviour. RBR850 and RBS850 are running V3.2.15.25_1.3.15.
The orbi app usually succeeds connecting immediately after rebooting the RBR850, but that stops working after a few hours (unless I'd reboot the RBR850 again)
- FURRYe38Jun 06, 2020Guru - Experienced User
Thanks for letting us know. I would open up a ticket on this so that NG is aware of your experiences as well.
pkgadd wrote:orbi app v2.5.4.1036 on android 7.1, android 9 and android 10 all show the same behaviour. RBR850 and RBS850 are running V3.2.15.25_1.3.15.
- farmrt88Jun 07, 2020StarCan you also pass along that the iOS orbi app version with the same issue is 2.5.2.1?
Thank you- FURRYe38Jun 07, 2020Guru - Experienced User
Information is already in NG hands. Thankl you.
Thank you- nakenergyJun 08, 2020Guide
Same issue on AX4200. Unless the router is rebooted the IOS app does not connect. Once rebooted it connects for some time and then the same issue.
