May 26, 2020Guru - Experienced User
Orbi App can't connect to RBR850 in AP mode...
Just wondering if anyone here in the Orbi AX forums has noticed that either Apple or Android versions or both, that Orbi app can no longer connect to the RBR850 when in AP mode? Seems that it wa...
Christian_R
Jun 02, 2020NETGEAR Employee Retired
Hello FURRYe38, farmrt88, and Toggil1,
I noticed most of you mention that you have Android. Would you guys mind confirming the current Orbi app version you have installed on your Android device. I've brought this up to our product teams, thanks everyone for bringing this to our attention.
Best,
Christian
farmrt88
Jun 07, 2020Star
Can you also pass along that the iOS orbi app version with the same issue is 2.5.2.1?
Thank you
Thank you
- FURRYe38Jun 07, 2020Guru - Experienced User
Information is already in NG hands. Thankl you.
Thank you- nakenergyJun 08, 2020Guide
Same issue on AX4200. Unless the router is rebooted the IOS app does not connect. Once rebooted it connects for some time and then the same issue.
- FURRYe38Jun 08, 2020Guru - Experienced User
Please open a support ticket and let NG know what your seeing:
https://www.netgear.com/support/product/RBS50Y.aspx#
Thank you.
nakenergy wrote:Same issue on AX4200. Unless the router is rebooted the IOS app does not connect. Once rebooted it connects for some time and then the same issue.
