JeffBobb
May 24, 2021Aspirant
Orbi app rejects admin login
My RBK853 (AX6000) router is rejecting login attempts from Android Orbi app. However, I can log in just fine through my desktop browser (Chrome), using the same credentials. I tried clearing cache, th...
JeffBobb
Android. Not sure what you mean by "RBR". Model is RBK853 (AX6000), though.
I haven't done a factory reset yet. I had a bad experience once, where a factory reset actually bricked the router. I want to check every other possibility before resorting to FR, since I can log in just fine through my PC. My gut feeling is that it's an issue with the phone or the app. I rebooted the phone, removed/replaced the Orbi app, but it's still rejecting admin logins.
May 24, 2021Guru - Experienced User
Ensure the android is connected to the RBR, This is the base router unit of the Orbi system. RBS are the remote satellite units.
Try changing the password after logging into the RBRs web page to something different. Then try the Orbi app. Ya, seems like the app is not working right. Can you try a different Android device or a Apple device?
