ekhalil
Oct 20, 2021Master
Orbi app starts with cloud connection
When starting Orbi app it always starts with the cloud connection (Anywhere Access). When it starts I can the go to the menu and change it to “Connect Locally”. It didn’t use to be like that, it just...
vTurner2
Oct 21, 2021Aspirant
When you press the Sync button, the LED on your Orbi satellite lights one of the following colors: Solid amber. We recommend placing your Orbi router and satellite closer to each other. Solid magenta. If the LED is solid magenta for 90-180 seconds, your router and satellite failed to sync. Solid blue.
