ekhalil
Oct 20, 2021Master
Orbi app starts with cloud connection
When starting Orbi app it always starts with the cloud connection (Anywhere Access). When it starts I can the go to the menu and change it to “Connect Locally”. It didn’t use to be like that, it just...
Oct 21, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi App product. Most of the people who watch that forum are more likely to have experience with Orbi App and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Others have reporting seeing this same thing. Maybe a new behavior that NG is putting out there since the Remote Management feature and it's advanced configuration has been replaced with something different.
Good Luck.
