justintan
Oct 14, 2021Aspirant
Orbi app
Hi I have the Orbi ax, rbr 850 and 5 satellites. I have switched this to AP mode and the app now cannot connect. Which makes sense, becasue in the setup section of the app, the IP of the router ...
Oct 15, 2021Guru - Experienced User
Be sure your device IS connected to the Orbi wifi signal and not the TPLink signal.
Orbi app does work in AP mode. Orbi app needs the Orbi signal to connect to it.
Disable any VPN on the mobile device.
