jimsix
Jul 30, 2022Aspirant
Orbi AX 4200 - Star vs Daisy Chain Connection Question
Hello. Please refer to the drawing below. I am planning to install an Orbi Wifi 6 Mesh Network in a small church building. Because of the thick sanctuary walls between the office and the classroom wi...
CrimpOn
Jul 30, 2022Guru - Experienced User
This is already a "Daisy Chain" because satellites 2 and 3 are connected to satellite 1.
Scenario A is the most efficient, and is probably what the system will choose for itself.
The owner has no control over how the satellites connect.
- FURRYe38Jul 30, 2022Guru - Experienced User
Depending on placement and how the RBS are turned ON, there is some control there.
- jimsixJul 30, 2022Aspirant
My question is can S1 (with a hard-wired backhaul connection to the router) serve as the center of the star (instead of the router) for satellites S2 and S3 and maybe more in the future?.
