arobinson8
Sep 14, 2020Aspirant
ORBI AX 4200 CHANGE ROUTER TO EXTENDER
Hi can you please help me with this. At present I have my main router in the garden office, running at 1Gb fibe-optic, cat 6 from the router to the house with an extender at the end of it. I would ...
- Sep 14, 2020
You can run it in access point mode. It'd work just as your diagram depects. in access point mode, it leaves the primary "main router from your diagram" running in router mode and just acts as a wireless access point and controlls the other satellites.
Sep 14, 2020Guru - Experienced User
Orbi routers can't operate in RBS mode.
arobinson8 wrote:Hi can you please help me with this.
I would like to use the mesh system. I'm looking at replacing my existing extender with the Orbi AX4200, making it an extender and using the 2 satellites.
My questions are.....
Can I make the Orbi router an extender and once it is an extender , will the satellites recignise the extender and pair with it?
I have attached a diagram of what I want to do.
Thanks Allan
