arobinson8
Sep 14, 2020Aspirant
ORBI AX 4200 CHANGE ROUTER TO EXTENDER
Hi can you please help me with this. At present I have my main router in the garden office, running at 1Gb fibe-optic, cat 6 from the router to the house with an extender at the end of it. I would ...
- Sep 14, 2020
You can run it in access point mode. It'd work just as your diagram depects. in access point mode, it leaves the primary "main router from your diagram" running in router mode and just acts as a wireless access point and controlls the other satellites.
Sep 14, 2020Guru - Experienced User
arobinson8
Sep 16, 2020Aspirant
how many satellites can the ORBI AX 4200 handle. I know you can buy the pack with 2 satillites , just wondering if I could connect another external one
Thanks
- plemansSep 16, 2020Guru - Experienced User
Official support says you can have up to 6 satellites with a maximum of 2 in a daisy chain. It says you can add more than 6 but expect performance hits.
https://kb.netgear.com/000062035/How-many-satellites-can-you-add-to-an-Orbi-WiFi-System
- arobinson8Sep 17, 2020Aspirant
thanks , great help
