OrbiRBR50_AG
Jul 13, 2021Aspirant
Orbi AX 4200 External VPN connection gets disconnected
Just got a new Orbi AX4200 Mesh wifi system. I get good speeds with my Orbi AX4200 (RBR750) but my office VPN (external VPN) keeps on dropping. The issue seems to be fixed after rebooting and it reoc...
- Jul 14, 2021
Thank you for the follow up. I tried to update on Orbi App but it said firmware is up to date.
Also, I didnt see the issue in 24 hrs after the last reboot. So, for now we can close this issue.
OrbiRBR50_AG
Thank you so much for helping out. Please find my answers in red below.
- What firmware version is your RBR750 running? v3.2.18.1 (Latest update)
- Is it a wired or wireless connection? Its wireless connection
- Do you know if the disconnection happens only when your pc is connected to the router (RBR750) or to the satellite (RBS750)?
- It happened with both if I am not wrong
- Do you have Armor or SPC enabled? If so, can you try to disable them from the Orbi App.
- Yes, Armor is disabled
- What VPN are you using? Big-IP Edge Client VPN
- Normally when VPN loses its connection, it would try to reconnect. Is there such a setting on your VPN client?
- You may also want to check with your corp IT to provide you with the recommended router settings that works with the VPN client.
- Its a possibility that your corp IT has forced your VPN client to disconnect after some time and you'll have to reconnect as part of security perhaps?
- The Idle timeout is set to 12hrs , I used to have an old Netgear router and with same VPN and never had this issue. This started only with my new router.
Hope this helps.
svetaketu
Jul 14, 2021Luminary
Hi OrbiRBR50_AG,
Thanks for the additional info.
I saw this article that might help: https://support.f5.com/csp/article/K31392274
There is a new RBR750 FW as well that you might want to try: https://kb.netgear.com/000063818/RBR750-RBS750-Firmware-Version-4-6-3-7?language=en_US
Hope this helps.
- OrbiRBR50_AGJul 14, 2021Aspirant
- svetaketuJul 14, 2021LuminaryHope the issue is now resolved. Thanks.
- FURRYe38Jul 14, 2021Guru - Experienced User
Please mark your thread as solved so others will know.
Enjoy.
