OrbiRBR50_AG
Jul 13, 2021Aspirant
Orbi AX 4200 External VPN connection gets disconnected
Just got a new Orbi AX4200 Mesh wifi system. I get good speeds with my Orbi AX4200 (RBR750) but my office VPN (external VPN) keeps on dropping. The issue seems to be fixed after rebooting and it reoc...
- Jul 14, 2021
Thank you for the follow up. I tried to update on Orbi App but it said firmware is up to date.
Also, I didnt see the issue in 24 hrs after the last reboot. So, for now we can close this issue.
svetaketu
Jul 14, 2021Luminary
Hi OrbiRBR50_AG,
Thanks for the additional info.
I saw this article that might help: https://support.f5.com/csp/article/K31392274
There is a new RBR750 FW as well that you might want to try: https://kb.netgear.com/000063818/RBR750-RBS750-Firmware-Version-4-6-3-7?language=en_US
Hope this helps.
OrbiRBR50_AG
Jul 14, 2021Aspirant
- svetaketuJul 14, 2021LuminaryHope the issue is now resolved. Thanks.
- FURRYe38Jul 14, 2021Guru - Experienced User
Please mark your thread as solved so others will know.
Enjoy.
