Chief2019
Mar 21, 2021Tutor
Orbi AX 4200 not connecting to Dell laptop
I have seen the other posts about this problem and tried the CTS fix without success. I have Netgear twice and have been hung up on twice. I have a corporate Dell E5470 running Windows 7. Can anyone ...
- Mar 21, 2021
Please mark your thread as solved so others will know.
Enjoy.
:smileywink:
Mar 21, 2021Guru - Experienced User
What is the mfr and model# of the wifi adpter in the laptop?
Ensure the wifi drivers for the adapter is updated fully from the Mfrs web page.
Disable AX mode on the RBR temporarily to see if the laptop will connect...
Chief2019
Mar 21, 2021Tutor
I have a Microsoft virtual WiFi mini port adapter#2 and intel dual band wireless AC 8260. I tried to update using the "properties" and both are up to date. Is the AX mode on the laptop or the Orbi?
