Chief2019
Mar 21, 2021Tutor
Orbi AX 4200 not connecting to Dell laptop
I have seen the other posts about this problem and tried the CTS fix without success. I have Netgear twice and have been hung up on twice. I have a corporate Dell E5470 running Windows 7. Can anyone ...
- Mar 21, 2021
Please mark your thread as solved so others will know.
Enjoy.
:smileywink:
Chief2019
Mar 21, 2021Tutor
I have a Microsoft virtual WiFi mini port adapter#2 and intel dual band wireless AC 8260. I tried to update using the "properties" and both are up to date. Is the AX mode on the laptop or the Orbi?
Mar 21, 2021Guru - Experienced User
You need to got to Intel's web site to download and manually install any updates for the Intel wifi adapter.
On the RBRs web page under Basic tab/wireless settings. Just uncheck the check marks and apply the change for each radio.
