Chief2019
Mar 21, 2021Tutor
Orbi AX 4200 not connecting to Dell laptop
I have seen the other posts about this problem and tried the CTS fix without success. I have Netgear twice and have been hung up on twice. I have a corporate Dell E5470 running Windows 7. Can anyone ...
- Mar 21, 2021
Please mark your thread as solved so others will know.
Enjoy.
:smileywink:
Mar 21, 2021Guru - Experienced User
You can if you don't have anything on 2.4Ghz that's AX supporting. I would try updating adapter drivers on the adapter, then re-enable AX on 2.4Ghz and see if the adapter connect with AX mode enabled.
