Spezaled
Apr 07, 2020Tutor
Orbi AX 6000 and AT&T fiber gateway issue
I recently purchased the Orbi with WIFI 6 and planned on using them in AP mode to extend my U-verse Fiber gateway modem signal. Got the WiFi set up just fine but now my U-verse TV signal locks up afte...
- Apr 09, 2020So AT&T came out and configured the gateway so that it all works now. They kept the tv feeds going to the gateway, set it to IP pass through and turned off he WiFi. The Orbi had to be set to router mode, not AP mode because of an IP conflict. Everything is running again.
skrishnan37
May 21, 2020Aspirant
DoctorA,
Let me ask dumb question about the dumbswitch. I was looing up the one you recommended, the GS105NA. Is speed affected by different models? There's an FS105, GS305. etc. I ask in regards to the GS105NA isn't available for a week or two vs the others I can get today or tomorrow.
DoctorK
May 21, 2020Guru - Experienced User
FS=100Mbps max connection rates.
GS=1000Mbps max connection rates.
