Tcrus
May 09, 2020Luminary
Orbi ax additional sattelites? RBR850
Currently have rbr850 and need an additional sattelite for full coverage of my home, where can I purchase an additional satellite?
- May 09, 2020
they've been going in and out of stock quickly.
Watch this site. right now its saying coming soon but there's been some popping up on there.
https://www.netgear.com/orbi/rbs850.aspx
May 09, 2020Guru - Experienced User
skeelo
Is there any info on the max number of satellites that can be added to the RBR852 system? I have not found anything and am running two (the one that came with the router and an additional I bought with my original purchase) but would like to add one or two more.
- KKSigsMay 10, 2020GuideI have the RBR 853 with one extra satellite, so running 3 total satellites without any issues. If like the AC series you may be able to run 4-6 satellites without issues.
I also got my extra satellite from netgear and used the 10% code. - FURRYe38May 10, 2020Guru - Experienced User
Has been any offical word from NG on what they support. Others in the Orbi AC forum have posted 6-9 RBS connecterd to one RBR. Something users will have to try to see how many. If users seem to run into problems after setting up the last RBS, then you maybe hitting a max limit with the RBR.
skeelo wrote:Is there any info on the max number of satellites that can be added to the RBR852 system? I have not found anything and am running two (the one that came with the router and an additional I bought with my original purchase) but would like to add one or two more.
