Retired_Member
Dec 18, 2019Orbi AX AP mode
Hi, I’ve set my Orbi RBK852 system in AP mode and now video streaming works fine; however all the devices appear to be connected to the main router, despite the satellite is fully working and conne...
Dec 18, 2019Guru - Experienced User
What does the app say for devices connected to the SAT? Nothing or some?
What version of app are you using?
Mine posts devcies that are connected to my SAT. I don't see the same on the router.
- Retired_MemberDec 18, 2019It appears as all of them are connected to the router. The sat list is empty
- FURRYe38Dec 18, 2019Guru - Experienced User
What is the distance between the RBR and RBS? 30 feet is beginning distance.
What happens when you turn down the RBR power on each radio. Say 50% to start. Under Advanced Tab/Advanced Settings/Wireless Settings
