Retired_Member
Dec 18, 2019Orbi AX AP mode
Hi, I’ve set my Orbi RBK852 system in AP mode and now video streaming works fine; however all the devices appear to be connected to the main router, despite the satellite is fully working and conne...
Retired_Member
Dec 18, 2019It appears as all of them are connected to the router. The sat list is empty
Dec 18, 2019Guru - Experienced User
What is the distance between the RBR and RBS? 30 feet is beginning distance.
What happens when you turn down the RBR power on each radio. Say 50% to start. Under Advanced Tab/Advanced Settings/Wireless Settings
