InOrbi
Jan 11, 2021Aspirant
Orbi AX daisy chain work around
I understand from the Forum that the new AX losses the abilty to turn daisy chaining on or off. Is there a way to work around this some how. I have an installation where i need a Satellite A cl...
Jan 11, 2021Guru - Experienced User
Daisy Chain is automatic now on Orbi AX. Placement, distance and power ON of RBS in seqence is key.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
- InOrbiJan 12, 2021Aspirant
The structure is +/- 5,000 square feet. the router is on Main floor at front side of house towards middle. That location is problematic to change. Satellite B is also on main floor spaced about 50 feet away. Sattelite C is on second floor opposite end up a level and 30+ feet router and 75++ feet and a level away from Satellite B. This all works great and extends coverage to the outer rooms of the house and into outside areas.
The issue is in putting a third satellite A in a media room / office on the basement level closer to Router than B or C. This allowed a hardwired connection without having to blow through several walls and a foundation to run wire. It all works great - except that the Basement Satelitte A will drop its connection from the main Router and 'find' and daisy chain to the other two satellites. When this happens, it causes the hardwired connected network devices to be 'lost' and need a manual restart. Once reconnected it can be 5 minutes of up to a day until the Satelite C decides to wander again.
Let's not even get into the annoying latency the daisy chain now creates.
Spacing the other satellites as far away from C helps buy more time between switching; putting one closer to force a 'dedicated' daisy chain connection did not work at all. Taking one or both of them out of the mix solves it - but kind of defeats the purpose of having wifi in the exterior rooms where needed. I can revert back to running a second wifi network and deal with those gymnastics.
Surprised that the basic functionality that existed previously has been removed.
I understand that the "Netgear" solutions is work within the limitations we put in our products....but going to be sad to see this system go over this as it has otherwise been great.
