sutset
Jan 05, 2020Guide
Orbi ax drops all 2.4 connection every 5 to 7 days
All my 2.4 connections both router and satellite drop every 5 to 7 days. A reboot always brings them back. Anyone else having this issue? This has been going on since latest software was installed.
Jan 11, 2020Guru - Experienced User
IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
sutset wrote:All my 2.4 connections both router and satellite drop every 5 to 7 days. A reboot always brings them back. Anyone else having this issue? This has been going on since latest software was installed.
