dcraig
Jun 15, 2020Guide
ORBI AX Guest Network not broadcasting on Satellites
I was hoping the latest firmware would fix the problem, but it hasn't. When I turn on the Guest network functionality, the SSID for the Guest network is not being broadcast by the Satellites. I can...
- Aug 22, 2020
I found the problem was being created by a Netgear GS724Tv4 24-port managed switch. Taking that out of the mix, and placing a Netgear GS108 switch on each end, and the RBR and RBS connected to the switches, they connect up properly and the Guest network functions as designed. Luckily I had an extra GS108 to try. It was the GS724Tv4 24-port managed switch that was causing the problem, even though I had previously disabled all IGMP protocols and green features.
FURRYe38 wrote:What mfr and model # switches do you have? Mine are D-Link and HP and mine work here when ethernet connected.
dcraig wrote:I found my problem was due to having switches betweent the hardwired Router and Sats. Once I removed the switches and had the Sats connected DIRECTLY to the Router via wired backhaul, the problem cleared up. Now the SATS are broadcasting the Guest network and there is interenet connectivity on it.
Jun 16, 2020Guru - Experienced User
Has a factory reset been performed on the RBR and RBS and setup from scratch?
