kjguli
Sep 01, 2020Aspirant
Orbi AX Mesh
Firmware Version V3.2.16.6_1.4.4 I have had my Orbi RBR750 with 2 satellites for a few weeks and in general am very happy. It has covered the dead spots I used to have. However, I regurlarly ha...
kjguli
Service Provider: Suddenlink
Modem: ubee UBC 1322
Satellite 1: 2 rooms and one floor between, ~40 ft from router
Salellite 2: 2 rooms and 2 floors between, ~30 feet from router
~ 40 feet between satellites.
Satellites positioned using Net Analyzer and Orbi App to get signal in dead areas.
fyi - walls are plaster
Channel selection is set to Auto.
5G band has always come been on Channel 48 and appears to be only WiFi on it.
2.4G band varies. I have seen channels 1, 4, 6 and 11. It is usually a different channel than the neighbors.
On one computer setting next to each other the 5G signal tends to be a few points stronger than 2.4G. The second computer is the opposite. I have also noticed the 2.4G strength relative to the 5G increases when the weather is cloudy and humid, and rainy,too.
I have a few devices in the house that only run on 2.4G. Will turning down the power output effect them? Can I turn down only the 2.4? is the power output managed for all device as a whole, or vary by device (router/satellites)?
Sep 01, 2020Guru - Experienced User
Your modem is a gateway wifi router already:
https://www.ubeeinteractive.com/?product=ubc1322
What mode is it working in? Router or modem only mode?
IF router mode, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
