DARIAN725
Apr 20, 2021Aspirant
ORBI AX RBR 753 Wired to Metal building/intermittent internet/modem issues as well
I have the Rbr752, purchased another satellite after. with a CM1200 modem. I recently built a wood framed metal building 25’ from the back door of my home. My home is about 2500 sq ft one story on a...
DARIAN725
Firmware version 3.2.18.1
Modem is my own, Nighthawk CM1200 Docis 3.1 Multi-gig
Both RBS’s are straight to the back of the RBR, no switch.
Other devices in the metal building also connect and disconnect as well, I have 2 cameras in the building, one is wired, the other is Wi-Fi and it does drop and reconnect several times daily.
I will take my laptop to the building tomorrow, and checked the wired connection as instructed.
I will contact my isp in the morning as well.
I have a Klein tools tester, I will check on the cable coming into the house.
Only 1
Splitter from the ISP, no junk.
Thank you for time and advice!
Only 1
Apr 20, 2021Guru - Experienced User
Might swap RBS around as well to see if the problem follows or not.
