Anyuser5454's avatar
May 14, 2020
Orbi AX router still needs firmware bugs fixed - latency, and slow satellite streaming
I have an Orbi RBK842. There is severe latency in connections between my mobile devices and the router. This latency happens when connected with either the router or satellite. Also, the connection...
  • Anyuser5454's avatar
    Anyuser5454
    May 15, 2020
    I think I identified why the Orbi AX series wasn't working out for me. The Orbi AX doesn't allow toggling "Enable OFDMA in 2.4 GHz" or "Enable OFDMA in 5 GHz." When toggling this option "ON" in my Nighthawk, my mobile device latency goes up to about 2 seconds just like I observed in the Orbi AX. When I toggle this "OFF," latency is in milliseconds.
    Orbi should add the ability toggle this on/off since some older devices, such as Apple TV 4K and iPhone X, do not support OFDMA, which likely leads to latency in some important scenarios.
